speedbirdted
Merry early Christmas to me, I guess.
I had a Goldberg Tiger a while ago and loved it, so why not get one of these. Hopefully I will have enough time to put this together before semester break ends for me in 2 more weeks. I don't anticipate much of anything crazy here in terms of mods but I think I'm going to at least try to add a steerable nose wheel which shouldn't be too hard to implement. I also forgot to buy wheels so I get to lathe those out of foam too.
I'm also going to try to cover it in Polyspan which is something I've never used before, but from the little bit of experimentation I did with it today I actually quite like it. It has properties of both fabric and tissue type materials, because that's really what it is - basically just polyester tissue.
I decided it would be a good idea to experiment a bit to see what can be done with it so I made like a dozen of these 2x2 inch square test pieces out of 3/16 stick and coated them in a bunch of random adhesives I had lying around in my house, just to see what could be used. I got the best results understandably from coating the base wood with nitrate dope and then going over the polyspan with thinner and more dope to secure it to the wood, but my supply of dope is limited and it's far too smelly for my liking. Same with Balsarite which smells a little better but I also don't have very much of it.
However, I made a very surprising discovery: Titebond works incredibly well, almost like Balsarite. I found if I brushed un-thinned Titebond onto the wood pieces to be covered, and then ironed the polyspan on, it re-activated the adhesive and tacked the polyspan down. From there I could shrink it and then brush more Titebond onto the polyspan where it was adhered with heat, and then seal the rest of the polyspan weave with Titebond thinned 50/50 with water. The straight Titebond applied to where the polyspan was adhered makes it incredibly hard to pull off, and it lets you feather the covering edges together nicely. My concern with this though is it took a lot of coats of thinned Titebond to completely fill the weave of even the tiny test patch I used and I'm concerned that this may add up quickly in terms of airframe weight. I'm curious if something like Polycrilic would do a better job to seal the weave and I'll try it at some point down the line.
I'm also probably going to paint it with latex now that I understand it a bit better. I'm wondering if even sealing the weave fully is even necessary as latex can do this to a small degree on fabric but I don't know how it works with polyspan. Another thing to test...
