Building away...
So I clamped the cabanes on out outside temporarily and adjusted things so the wing spacing is the same as the chord width.
Proportions look pretty good here...
Nothing is glued down here so of course it's tilted all over - but you can see the wingspan difference between the top and bottom.
TLAR for cutting the front leg of the cabane off since the battery tray is already installed...
And with a little nudging, a level, and an incidence meter things are looking pretty decent.
So I'm going with the top wing at 2 degrees - you can see the orange level keeping the datum line across the top of the fuselage and horizontal stabilizer at 0. The semi-symmetrical wing on the bottom just naturally wants to sit at -1 degree which gives a total spread of 3 between the wings.
Doing a negative on the bottom wing isn't very common - but it's also not unheard of. The whole system could also be looked at as the bottom being being at 0 degrees with a +3 on the top wing and a +1 on the horizontal stab, which is a setup I've seen discussed on a forum talking about F3 pattern biplane designs. Course in that example the wings were the same width, so not all variables are equal by a long shot.
I'm thinking I'll do the bottom wing as a bolt in, while keeping the top rubber banded for ease of construction.
Anyone have ideas for what WW1 plane this setup most resembles? Are we still in Tiger Moth land Joe?
