I'd test the floppy disk material before using it. It has to be over thirty years old. It probably has deteriorated to some degree.I've heard of doing this, and have some tyvek & actual 5.25" floppy disk material stored away somewhere to try for CA hinges someday too.
@rockyboy - you battery charging makes my 'one at a time' charging look ridiculous!![]()
You know, you've been saying that since? 2015? Earlier? I'm not saying anything, but it might just be time to remedy that. Just throwing it out there...Not being a fixed wing guy....
You know, you've been saying that since? 2015? Earlier? I'm not saying anything, but it might just be time to remedy that. Just throwing it out there...You can rip a quad like nobody's business. You decide you want to fly an airplane, I'll help you out. I guarantee I can help you crash in style!
It's not all that. @rockyboy thanks for letting us take this little detour. I just feel for you @PsyBorg! You've been at it for so long. I'm willing to help. Really. If you've got two sheets of foamboard and some hotglue, I (and many others who know way more than I do) will help you fly fixed wing. I'll even start the thread if you want. The question is, do you want? Really. If you don't really care, then no sweat. If you've just a mental blockage, then I've got the painless build and easy flying plane for you. Your call.See you have not been paying attention mate. I have posted ALL of my Fixed wing attempts here. Starting with the Bloody Baron plans Rockyboy sent me when we did the Caudron challenge. Then it was the FT3d, Then it was the FT edge, then the SE5.All with multiple attempts and rebuilds documented. Then Turboe Joe and Rockyboy teamed up and sent me two Balsa planes known to fly one a beautiful cub and the other a low wing I have spaced on the name. Those I am scared to fly after splitting the cub wing in half. Ill save them for after I stop breaking foam.
Now I have ready to try again the Edge, the SE5 and the Dat Rhino Kilroy dropped off to me at the last FFO I was able to go to.
I have learned a few things and found several issues that needed correcting. One was what I "thought" was a little nose heavy was actually a LOT nose heavy. So now EVERYTHING gets multiple glide tests. The other is suffering from quad brain and dropping throttle the second I feel anxious instead of powering thru or out of a stall. Once I defeat quad brain I will have successful fixed wing flights I am sure. I can even do some 3d in the fixed wing sim I have so its all mental at this point not skills holding me back. Of course having to fly alone all the time without someone there to slap me in the head and tell me to throttle up instead of down when things start to happen does not add speed in learning.
Sorry Jon for detouring this thread mate.
I was more thinking along the lines of inside edge solid where the control rods are vs outer edges with less support kind of making a twisting action if you can picture where my head is.
Just click on the link in his signature. He's got more kits than Amain!@rockyboy - this build is really coming along now - I tried the fishing line hinges before the micro cable ties, but I think the issue I had was my line was too thick - I imagine you have a great fleet tucked away!![]()
Wow - that’s a LOT of planes! I thought my hangar was full...Just click on the link in his signature. He's got more kits than Amain!
