TooJung2Die
Yes, compared to opaque film, it is a P.I.T.A.Transparent film is a royal p.i.t.a.
Unfortunately not, it's been a wild five months for me and I haven't really been active in the hobby lately. It's been sitting on my nightstand.any updates?
How much would it cost to put together a simple bungee launch for my gentle lady?Great work so far! I built a fullsize Gentle Lady earlier this year and it's an amazing plane. It does amazing with a bungee hi-start. Though, I wouldn't try this one with a full 2-meter bungee because you would probably rip the wings off. You could probably get a length of surgical tubing to do launches with.
Also that battery is... not gonna workI think Doug has been flying his with a 350 2s and he says it's perfect. You really don't need much power at all with one of these things, mostly the motor is just to find thermals. If you plan to use no motor you could probably use a 1s if you can find a reciever that will operate on that voltage. You could maybe use a BEC.
You say that like you have a currently airworthy Gentle Lady.How much would it cost to put together a simple bungee launch for my gentle lady?
Not quite airworth - yet! I still need to order covering for it. I really want to make it bungee launch rather than put a motor and prop on it, but it would probably be easier and more practical to just put a motor on it - not as cool though.You say that like you have a currently airworthy Gentle Lady.
You could build one for probably 30 bucks. I use 60 feet of 1/2 OD surgical tube with I think 300 feet of 50 lb test line attached to it as the tow line with a rag tied near the top as the chute. I pull it to about 10 pounds - the gentle lady weighs 22 ounces, and any pull force around 5-10x your AUW will give you a quick descent, anything less may be anemic and more may be violent.
A dog stake works well to anchor the bungee end down. You can also use latex tube which will be more UV resistant, I only used surgical tube as I have a source I can get it cheaply from.
i agree the bungee is way cooler!!!!Not quite airworth - yet! I still need to order covering for it. I really want to make it bungee launch rather than put a motor and prop on it, but it would probably be easier and more practical to just put a motor on it - not as cool though.
Not wrong, really. I just like the bungee because it keeps everything simple (and can let the glider weigh less) but it has some disadvantages... for instance it takes a LOT of practice to do a bungee launch solo. Usually you will need another person to hold tension on the glider and release it while you fly it on the way up. With a motor if you get too low just put in some power and you're back in business thermal hunting in no time. My gentle lady also needed nose weight too (3 ounces) which I could have added in the form of a motor and a bigger battery.Not quite airworth - yet! I still need to order covering for it. I really want to make it bungee launch rather than put a motor and prop on it, but it would probably be easier and more practical to just put a motor on it - not as cool though.
It's a mentor only thing sadlyNot wrong, really. I just like the bungee because it keeps everything simple (and can let the glider weigh less) but it has some disadvantages... for instance it takes a LOT of practice to do a bungee launch solo. Usually you will need another person to hold tension on the glider and release it while you fly it on the way up. With a motor if you get too low just put in some power and you're back in business thermal hunting in no time. My gentle lady also needed nose weight too (3 ounces) which I could have added in the form of a motor and a bigger battery.
On an unrelated note... they let you change that subscript thing under your username now? Or is it a mentor only thing?
I need to get that...
Honestly the covering was what I was having trouble figuring out. It's not that it's particularly difficult I just don't know the method for covering the nose on a plane like this. Especially since I'm using transparent film.Not quite airworth - yet! I still need to order covering for it. I really want to make it bungee launch rather than put a motor and prop on it, but it would probably be easier and more practical to just put a motor on it - not as cool though.
Same, I’ve never done any covering work. I don’t even have a covering iron!Honestly the covering was what I was having trouble figuring out. It's not that it's particularly difficult I just don't know the method for covering the nose on a plane like this. Especially since I'm using transparent film.
Have you started trying to cover the fuselage yet?Honestly the covering was what I was having trouble figuring out. It's not that it's particularly difficult I just don't know the method for covering the nose on a plane like this. Especially since I'm using transparent film.
So kind of like a clamshell over the nose?Have you started trying to cover the fuselage yet?
I immensely dislike using transparent colored film over a solid sheet fuselage. Mostly because if you have spots where the covering overlaps, these will be less transparent and hence more colored. It's so bad that any spot like this stands out from a mile away. The only exception to this is clear film as it does not suffer from this problem. I would recommend using an opaque color - white or silver generally look good on gliders.
As for applying the covering, use one sheet on each side, and either one wrapping around the nose from the hatch to the bottom of the fuselage or one that goes from the hatch to the point of the nose and then one more on the bottom of the fuselage. Apply the side pieces first and then the nose piece, and if the nose covering is in two pieces make sure one overlaps significantly and the seam is facing downwind so air resistance will not try to lift it. The top and bottom piece(s) will then shield the side pieces' seams. If you use a little more heat on the iron you can roll the edges over the rounded corners to seal them off nicely as well.
