Wing assembled and glued with the swept back tips this time - it will make the plywood angled spar that holds the sections together fit a little funny, but I like the look of it this way.
Also shown are the led's and resistors generally put in their spots. I'm using the existing guide hole as the place for the resistors to go - they glue in there with a little Super Phatic just fine. The extra balsa sticks are just holding the resistors straight until the glue dries.
Also took advantage of having a plastic sheet over the workbench to lay out the wiring diagram with a marker. The reason I'm doing them in little pairs has do to with the voltage drop from the leds, and wanting to run this plane on a 2s battery. Basically, each led is causes somewhere between 2 and 3 volts of drop when in series (depending on color) so by wiring them into little paired cells they will still have all the volts they need even when the 2s lipo is empty and ready to land. This is also why you can easily find led power supplies with 24 or 48 volts - they can run a longer series of lights on fewer resistors and less complexity. As for the odd location of the resistors, they don't specifically need to be in front of or behind or between the led's to work properly - it just works out nicely for wiring across the ribs to have them in between.
