The wing is just missing covering, which I have the material, just short an iron... although I am also out of red...
Right now I'm "ummmm'ing and arrr'ing" over details with another project which in tamagochi terms would still be just an unhatched egg still... I have my eye on a balsa scratchbuild, but I want to make a couple of modifications to it, and debating how best to do it. The plane I have my eye on is a french design miniature plank wing called "Fiu" which I think is a really beautiful design for a low wind slope plank with a slight inverted swept wing, only 740mm in wingspan and 360mm in length, which I would like to make with the 2 wings independent rather than one whole wing, make a carry case for it which would only be about 400mm long, and add a rudder in the mix so my left hand doesn't get bored... maybe a split rudder even to use as an airbrake, although that would be hard to do with a 2mm thick rudder...
The plane is desighned to make almost completely out of a single sheet of 2mm balsa, but I would make changes like use carbon fiber on the wing spars instead of balsa, maybe cover the leading edge in 0.5mm balsa, things like that. When it was designed in the late '90s, it was weighed for use with NiCd batteries, larger FM receivers and elevon mixer onboard, all of which can be saved now with a single cell LiPo, 2.4ghz system and the mixer in the radio. I would need to get hold of a 2.4ghz module for my radio for this, as having a 35mhz antenna hanging behind along with the fish design would make it look like one of those typical goldfish that does its business and it's left hanging behind it!! Yukkkkk!!
