Wing glued at slight angle to main fuselage direction
Flying.Nevs
Hello,
while glueing the wing onto the fuselage of a foam board warbird (wingspan ca. 65cm) I accidentally attached it at an angle of ca. 2.5° instead of perfectly perpendicular, resulting in one wingtip being 1.5cm / 0.6inch in front of the other.
How strongly will this affect the behaviour in the air (will this be possible to trim out permanently), or would it be best to cut the fuselage off and try again?
In case a keep it as is, should the horizontal stabilizer also be attached at a slight angle so that it is parallel to the main wing?
Thank you in advance
