Hello, and thanks for letting me on the forum.
My question is basically the title. I'm building one of those infamous "pizza box" fliers (a square piece of foam with a motor, elevons, and a vertical stabilizer).
One of the issues that led to today's fatal crash was it kept on trying to pitch up and stall. My 2 solutions are: Moving the motor to be more in line with the middle instead of above like high-wing aircraft (they tend to pitch up violently with throttle, making it a mid-wing is probably easier than playing with thrust angles), and shifting CG more forwards (20%). Part of idea for the second solution is downgrading from 4 to 3 channels, by going elevons only and not using a rudder. Strakes that are along the length of the wing will concentrate less mass at the back, thereby shifting the CG forwards.
So are strakes with a large enough area a viable substitute for a vertical tail fin? Is there something I'm missing about the aerodynamics?
