Another day building and another issue! Can I pop a note at the start to say I have never done wiring before, neither has my son, so please do let us know in very basic language on what we need to do!
We have put our motor into the power pod, screwed on, connected to the ESC and receiver, along with the servo's. We have used CH3 for the ESC, and CH2 for left servo, CH1 for right servo. We have turned on the transmitter, we get the right sounds we think, a little movement in the pushrods from the servos.
However, my son moved the elevator right hand stick up and down, only the left pushrod moves moving the left aileron. if we move that right stick left and right then the right side aileron moves but the left side does nothing. we had switched previously and the opposite happens. What do we need to do to make both servos kick in so that when he pushes the right stick forward and back both ailerons/elevators move? and then when he pushes that same stick right or left how do we get one of each to move in opposite directions to turn the plane?
I apologise now if I am using the wrong terminology for all things!
I have popped a photo of the receiver and wiring. My thoughts are is this a transmitter thing but maybe we've got more wrong than that!
last thing - should I take out this pushrod and re-do? the servo horn is a little bendy, again no idea if I can just take out the rod or if we have to try and get out the whole servo (glued in). View attachment tempImageXUsqKu.jpg
very best and thank you
