Hey guys, I have recently bought a wizard x220s and set it up through betaflight. I took it for a test flight and had a little crash into a bush. I quickly unarmed the quadcopter and went and retrieved it.
I noticed after flight time was at 4mins so I thought that's enough for the first flight and went to recharge the battery.
After the battery was fully charged, I tried again and I noticed when I turned on the drone, the props didn't move at all (the first time they all moved slightly when booted up). I continued to arm the quad and the appropriate lights came on to show it's armed. But none of the motors spun.
I then plugged it in the computer and tried to diagnose the problem and in the motor tab, I try to manually power the motors and the values come up but again, the motors aren't spinning ?
I noticed when the drone is powered there is two short blinks on the top circuit board. When armed there is a solid blue light on the second from the top circuit board.
Just wondering if anyone knew what's going on?
