This review is about the quad copter available at this link for about $45 US shipped:
http://www.banggood.com/Wholesale-Wltoys-Ladybird-4-axis-Dexterous-Mini-Ufo-Rtf-p-46172.html
If you look at the page linked above everything I cover is in pictures there as well as customer mods and videos.
I ordered mine in early October and also a 5 pack of Tigers 1S 600mAh 15C LiPo's.
Banggood had shipping problems with Chinese customs and had a small mountain of packages returned to them so it had to be reshipped. For my trouble and the delay they graciously refunded 30% of the price immediately. I Finally received it Tuesday the 13th day of November.
It was packaged securely in a purpose made foam container and was fully assembled.
The contents were as follows:
A fully assembled Quad Copter as seen in the photo at the bottom of this post,
4 extra blades
1 battery and wall charger with adapter for USA wall jacks
2.4 GHz Transmitter
Chinglish manual
And of course the 5 extra batteries I ordered Plus an extra control board that I had ordered as well.
Total after my 30% back was about $47 delivered.
The copter is rumored to be identical to the Blade MQX with most if not all parts being interchangeable.
Another plus is that it readily binds to the Turnigy 9X.
The canopy is kinda hokey (I received a green one as there is no choice) but can be replaced by many paper designs available by a search at RC Groups or Google or made from many household items. My favorite is the bottom 1 1/2" of a disposable plastic drink cup which can be made in less than 5 minutes with little more than a pair of scissors (a hand hole punch makes it even faster).
The included 2.4GHz Transmitter I received is Mode 2 and is a smaller form factor than a full size such as the 9X and is run by 6AA batteries.
It has several features that make it ideal for beginners.
It boots up in a mode with only 20% of full throws which translates to a VERY docile flight.
A button on the top left of the transmitter allows changing from the default 20% in steps to 40%, 60% and 100%
I use 40% or 60% for most of my flying.
At 100 percent things start to happen for this craft.
Sudden control motions translate to a flip or roll which I would NEVER try on one of my more expensive multi's.
To flip or roll just make sure you are set to 100% then establish a hover about 8' high (or higher) then momentarily pull or push the stick to it's limit. A complete roll or flip will occur and the craft recovers nicely with little user input.
The props on this quad are somewhat flexible and resist breaking in crashes.
I haven't broken anything yet and I have crashed into concrete from 10' up.
The arms are square carbon fiber tubes with the motor wiring run inside it.
The blades are turned from a small high speed brushed motor driving a pinion gear attached to a carbon drive shaft which attaches to the blade with a screw through the blade shank and through the "drive" shaft.
I have modified the landing gear on mine with a TyWrap attached to the bottom of each of the 4 "legs and curled back towards the center of the craft as seen below:
I would recommend this craft to anyone from Beginner to experienced multicopter pilot. Sometimes it is just nice to fly something you don't mind crashing because first it was low cost and secondly it doesn't break easily.
All parts are available if you manage to break it and are fairly low cost as well unlike heli's which tend to break the bank .
Thurmond
4 extra blades
2.4 GHz Transmitter
Chinglish manual
Thurmond
