jlhart1982
Hello,
I have a X Style quad frame with Naza Lite Flight controller, This is almost identical to the Flamewheel 450.
my current setup is :
Dimension : 490mm x 490mm x 140mm
Motor to Motor : 450mm
Propeller Size : 8" X 4.5" Carbon Fiber Propeller
Take off weight : 850g (Max safety 1350g)
Motor : 2208 Brushless Motor
ESC : 10A with BEC
Battery : 11.1V 2200mah 20C
after switching out the stock gyro board with the Naza i have been getting only a few minute flight, maybe 5 minutes tops, is there any way i can get longer flight times? i want to eventually do FPV and i cant see a very enjoyable flight if i have to land every 5 minutes.
Also after setting up the Naza it kinda drifts forward continuously a little in attitude mode, is this normal?
Do i need to get more efficient ESC's, i have a 5000mah battery i can use, but im afraid of it affecting flight cause of the heavier battery.
ESC : 10A with BEC
