XF A-4 Skyhawk EDF
XF A-4 Skyhawk EDF v8
Please log in to download
Mid7night
Jetman
Mid7night submitted a new resource:
XF A-4 Skyhawk - The XF A-4 Skyhawk is a 3-channel EDF jet designed to be easy to build and fun to fly.
SPECS
Span: 30 in.
Length: 43 in.
Empty Weight: 27 oz.
Power: 70mm EDF
Battery: 3000mAh - 5000mAh 4-cell Lipo
Flying Weight: ~45 oz.
I highly recommend a 12-blade EDF, but this jet will fly on any similarly-powered fan regardless of the blade count.
Check out the build thread for reference pictures, questions, answers and discussion...
Read more about this resource...
CrshNBrn
I came across Ben Harber's plans for this little Skyhawk. There's no active links anymore for any build instructions or discussions, but I had an extra 70mm EDF sitting around from his F-16 Viper build that I destroyed (see "What Did I Crash Today, page 8")...so what the heck? I'll give it a try and see if I could figure it out.
I tried to take a few shots of the nose pieces. I'm not sure if I did them correctly, but they seemed to fit. If you've built Mid7night's Viper, you'll recognize how he does the cockpit area as its the same for the A-4. I used a couple of magnets to hold the back, but it probably doesn't need them.
I also moved the servos to under the wing, however, I would recommend to anyone else to stick to the plans and install servos on the top to avoid them being ripped out on belly landing. To prevent this, I 3D printed some servo protectors.
I'm guessing the CG is around the front chord of the wing. It seems to balance there with a 4s 3000 battery, but there's no way of knowing for sure until I can fly it.
Mid7night
Jetman
That's awesome! Thank you for having fun with my plane and showing your build!! Also thank you for reminding me that all my signature-links were broken :p
They should be fixed now. :D
