TooJung2Die
Thanks! The only simulation is me trying to look like I know what I'm doing up there.That was some seriously smooth flying, It looked like a simulator!
I can move the CG around easily now that the battery is close to centered on the CG. It kinda feels on the edge of tail heavy the way I've been flying it. I think tail heavy is the way a 3D airplane is supposed to fly. But what do I know? I'm a total noob when it comes to 3D. Do you have any experience? I'll play around with CG and see what happens... if the wind decides to die down. It's been gale force the last few days.Have you considered moving your CG back?
I will. That sounds counter-intuitive and crazy but it makes sense if the goal is an easy to hover 3D. All a tail heavy airplane wants to do is fly nose up. For normal flying that's very bad. Would you say you want the airplane to be neutrally balanced so it'll fly flat and prop hang? Too many 3D YouTube videos are boring because all the flier shows is an airplane hovering. I think practicing slow high-alpha will be useful for indoors in the winter.If I had your Yak I would inch the battery back until it didn't fly well anymore.
Since the double layer DTFB Yak now flies better than expected it deserves some decoration. It also needed something to help with orientation. It rained all day so a little quick-n-simple airbrush masking and stenciling made up for not flying. The DTFB will be the windy day 3D Yak. The MPF Yak will fly on calm days or indoors.
These airplanes are great for making you a better pilot. Because they are so cheap and easy to build it eliminates the fear factor of crashing. A good RC pilot at the airfield coached me through flying inverted for the first time. It flies inverted hands off, no elevator input needed. He never would've talked me into that with a balsa airplane that took months to build.
Well, if it flies hands off inverted, that's what you want! Sounds like you've got it balanced pretty well, and it looks great to boot!
Thanks! What I want now is to figure out how to turn off what my brain has been trained to do with the elevator. Trying as hard as I can I can't seem to get my fingers to move in the opposite direction when flying inverted. It is very frustrating. As soon as I attempt an inverted turn I screw it up. Anyone have some advice?!?
Flyboa made one like that and it flew very well. There's a video of it on his YouTube channel. If I made another with DTFB it would be one layer, no paper. It'll need strategically placed carbon fiber to stiffen it up. It'll be fragile and not survive crashes or hard bumps but it'll be light. MPF is a lot like DTFB with the paper removed but stronger. EPP foam seems to be the material of choice for this type of airplane. It's very light and springs back from crushing and bending. It too needs carbon fiber stiffeners because it's floppy.I wonder if 2 layers of FB are necessary. Would a single layer of paperless FB would work? How much weight would it save?
I hear that. I think some simulator time is a good idea to retrain the brain. Then I can crash it endlessly.In sort, muscle memory. You just gotta practice.
