Maiden success! I was able to get about 6 minutes airtime in today before the after work dog walking crowd started to take over my "airfield" and I had to call it.
Here is a quick vid from the "head cam" of it's first takeoffs, passes and landings.
So first reactions.
- It flies! WOOOOOOOT! :applause:
- CG is still tail heavy, but MUCH better than before.
- Tail heavy planes want to roll!
- Thrust angles seems great.
- KFm3 has great handling and stall characteristics.
- Flies like well at 1/2 throttle, but not much "emergency" power.
- Replacing 2650 mAh 2S battery with a 3300mAh 3S to gain more prop rpm and nose weight.
- Elevators could be more responsive, making them 100% longer.
- Rudder gives great coordination, but won't crab in forward flight. Extending 100% too.
- Ailerons are super responsive, 25% expo seems about right.
- Differential is working great, coordinated turns gives no skidding.
- You can "hear" the difference from the props in turns with rudder vs no rudder.
- Flaps at 4* makes things nice and tight. Needs more experimentation after tail changes.
- 1" foam is about indestructible.
- Hand launching a 50" wingpsan is not super easy.
- Full throttle before letting go, and throw it UP!
- Did I mention it flies!?
- This thing is begging for some FPV flight.
