Ranger_107
@Zephyr1 designed this F-86 Sabre that runs off a 50mm EDF. The original build has a 32-inch wingspan and is 28 inches long. Scaled up its should be a 40-inch wingspan and is 35 inches long. I plan to run it off a 70mm BDF style ducted fan. I plan to run it of a 4s 2200mAh lipo or a 5s 3000mAh lipo. I have landed on the EMAX Eco 2207 2400kv Brushless Motor and the EMAX Formula 45A ESC. I am going to use 5-gram servos to keep the weight and cost down. I am going to put Fowler flaps and retracts. Retracts are coming from the Freewing 80mm F-86. Its an entire gear set so I wont need to get anything but that for the gear. The plans are currently being put together today. I am about halfway done with it.-
PARTS-
EDF Unit-https://www.horizonhobby.com/produc...5c30xGCBpTiAhvfW1R3KnZl441umbeqRoCMy0QAvD_BwE
ESC-https://www.racedayquads.com/produc...8ZJ5lV92Or9z6-ruQWqkBzjRRjWz061hoCb8UQAvD_BwE
Servos-https://www.racedayquads.com/products/emax-es9051-4-3g-digital-mini-servo?variant=31485582508145
Battery (4s 2200)-https://hobbyking.com/en_us/turnigy...i-jC8plix4PE42f4zGxoCxZkQAvD_BwE&gclsrc=aw.ds
Battery(5s 3000)-https://hobbyking.com/en_us/turnigy...zuu6q1axrg7o9nhNWPxoCCqYQAvD_BwE&gclsrc=aw.ds
I am going to be building this over a while and might need some help to decipher what part goes where on the plane.
Please tell me if you dont think that the parts I have chosen will work or if I will need to change some things.
Thanks for any help or advice!!
Nick aka Ranger_107.
PARTS-
