Maybe two with the wings.One sheet as far as I recall.
Yeah the PDF is sized to a sheet of DTFB, so the whole fuse takes one sheet. That doesn't include the nose cover, which on mine I just put it nose-down on a piece of scrap foam and cut it to size. I still need to make a camera holder nose but I'm procrastinating because it may be hard.Sorry if you covered it but how many sheets does the fuselage take?
Good luck!Yeah the PDF is sized to a sheet of DTFB, so the whole fuse takes one sheet. That doesn't include the nose cover, which on mine I just put it nose-down on a piece of scrap foam and it to size. I still need to make a camera holder nose but I'm procrastinating because it may be hard.
I've got iNAV installed inside now and got it all set up last night. I took it out for a test flight and oops, got my orientation wrong so it immediately goes into a roll of death when you turn on stabilization. About to head out this morning and give it another go.
Very nice man! i am going to build one too some timeWe dooed it! I had plans of putting the VTX in the wing like you see on so many builds, but ugh, then I'd have to make a cable and dig out chunks of foam from my pretty wing and who has the motivation for that? I just cut a hole in the side of the fuselage and trapped the VTX between two layers of tape. I got a little carried away on cutting so the hole is a little big but nothing life-threatening.
I also made a quick insert for the cameras. I had a real problem here since I planned to insert it from the front and then use something to lock the camera unit with the action camera and the FPV camera in place. I didn't really think it through because the nose comes to a point in the vertical axis so it can't take in something wider than the orifice. No problem, I'll just come in from behind and the vertical slopes will lock it in that way! Nope, the body tapers so the canopy opening is too narrow to fit anything that would fit snugly in front of it. Oh well, I just cut down the block a little until it fit in through the canopy area. It slides all the way forward and there's a magnet on the roof that prevents it from sliding back.
You can see it is a little "gappy" up there. Everything is just press fit into place. The right side of the action camera (left in photo) inserts into a hole in the camera pod, and the same with the FPV camera. The two are just the right width that they wedge against each other. There's a hole in the top of the pod to allow me to press the buttons to start recording, so I just push it from the front to disengage the magnet, press the button then push it back in. Very simple single step.
But enough of this chit-chat, yak-yak and flim-flam. Just refrain from hibernating and we'll all enjoy the show. (Youtube is taking its sweet time processing this, it should be up soon)
You can tell when I'm in ANGLE mode, since the autotune procedure made the pitch bounce up and down. Just need to dial down some of the PIFF gains there. The V-Tail has the 60/40 elevator/rudder mix I had before and it feels like it isn't enough in manual mode so I might try 60/50. It takes like a year to rudder turn this baby around. Other than that, this build is done apart from some minor tweaks of the iNav settings. New equipment:
- Omnibus F4 Pro v2 Flight Controller
- Beitian BN-180 GPS
- Akaso V50 Pro Action Camera
- FrSky R-XSR receiver
- 18A T-Motor ESC
- AKK X2M VTX (maxes out at ~300mW despite claims, not recommended)
- Foxeer Monster mini FPV camera
- 655g weight with everything on board, 125g is battery
Finally to experiment with that horrible tip stall problem, I 3D printed a 256mm wide x 8% chord (14mm) x 2mm tall strip of vortex generators at a 12 degree angle and a 21.2774mm spacing (2 * 10 * vg_h * vg_d * 0.75 / (PI * PI * vg_h)). They are installed to end at 14% chord, so they start 11mm back from the leading edge.
I got them from the FliteTest article of course!Where does that formula come from? I've wanted to experiment with VGs, but wanted to try something more methodical than "put some bumps on the wing and see what happens".
That sucks! Though the project was a success!I put an 8x6 APC Electric prop on in place of the 8x4.5SF and I got more power and a little more efficiency. At 4.25A I was cruising around at 50kph. I could tell right when I took off that I was tailheavy since the plane was eager to climb but I wasn't planning on flying long so I just ignored it and added some down elevator. Five minutes in and was just circling the field one last time before landing with the throttle real low, 2.5A / 27kph. The nose still wanted to bob up so I cut the power completely to see what would happen... huge tip stall at 98m! I rolled upside down, recovered, stalled full nose down again, and lost 60m of altitude in under 4 seconds. I tried flipping into stabilized ANGLE mode to let iNav do some magic, but I was too late: impact velocity was -25.83m/s or 93kph and over 12Gs of deceleration.
The fuselage is toast. Even the 3D formed center support was ripped to shreds. The flight controller ripped loose and went flying. The MMCX antenna snapped off the VTX, which then burned itself out. Both V-tail fins snapped off. Even the GPS module, glued in its tiny protective area came loose and its wires sliced through the DTFB. The bbq skewers in the nose were exploded into woodchips. The AKASO V50 Pro action camera still works, but its LCD is shattered and just displays random pixels now so that's a loss. The Foxeer Monster FPV camera still works but there's a big scratch on the lens. So about $150 worth of electronics broken.
The wing is a real success story though, there were a couple tufts of grass stuck to it, and part of the paper covering chipped in one place, but it is 100% strong, unbent, and even the control surfaces are still solid. I'd say I'd build a new fuselage and get right back to flying, but it is a bit expensive to replace all the camera gear so the project will have to wait. I also think the lack of washout in the design helped contribute to the disaster so I'd probably want to do a new wing anyway which is a shame because this wing is so dang strong.
Galleon adventure OVER.
Oof we share that feeling. This is actually the first recovered crash where there was damage to any of my parts, so my disappointment was spread across various highs and lows. I crashed. But it crashed on open ground so I don't have to fish it out of a tree! Oh the fuselage is busted up. But all everything is right here! X is broken. But X is only mostly broken!In one swoop I lost a $70 camera, $30 ESC, and $24 RX. Brutal day.
Do you have plans available for this? Looks great!I have been working on a version of this myself actually. Flew it for the first few times this weekend.
I found the same issue with the aft end as you did during the build as I was referencing original product photos as well as your plans and build thread. Its even more pronounced in my case as all the hardware is what I had on hand so I'm running a 2306 1750kv with a 6x4 and there is literally millimeters of clearance at the tail and propeller tip. Im going to print a spacer/mount and give myself a couple 6mm more length just to be safe and maybe quiet the thing down a tad.
Flies for well over 25 minutes on a 2650mah 4s at about 50%-55% throttle. As you said it doesn't like to go slow, this thing is a barn burner for sure and once it gets down on the deck for a landing it just goes and goes and goes... Eventually you just have to shove it down onto the ground it seems.
Working on an edit of my last tuning/distance test and will post a link when it's up. Managed to hit 2.25 miles on 5.8ghz and not even very good conditions.
(Edit to include link)
iNav UAV Tuning Session
Glad to see you getting back into this project and am looking forward to seeing how it progresses from here.
-Clay
Wow that looks incredible! Looks like it flies great in the video too. Did you build that from my sketchy plans, because that would be a miracle.I have been working on a version of this myself actually. Flew it for the first few times this weekend.
