The Fopster
Just starting an experimental build of a Grumman F8F Bearcat. If it gets finished it will be 1.7m span and very approximate in terms of scale detail. The payback will be that it should be a very quick and cheap build.
Material will be a mix of Hobbycraft foamboard (heavy UK stuff) and B&Q home insulation foam sheets. Plans are being done extrapolating from a 24in span balsa control line design, blown up to 270%.
Tomorrow I’ll try building one wing and see if the design works. If it doesn’t I may park the idea.
Here goes nothing!
Here goes nothing!
