Type
Build Plan (PDF, AI, etc.)
FT Baby Blender
Designed By: Josh Bixler
Plans By: Dan Sponholz
Description:
The Baby Blender Swappable is an excellent transition into four channel flying and more advanced building techniques. With gentle stall characteristics and a wide speed envelope, the Baby Blender will enable you to experience all the benefits of four channel flight. Tight loops, rolls, hammerheads, snap rolls, inverted, and even high alpha are all possible with this design. The Baby Blender will quickly take away your intimidation of flying a four channel biplane, and take you back to your childhood when the only limitation was the lead in your pencil and the size of your paper.
Speed Build Kit:
FT Baby Blender Speed Build Kit
Power Pack Compatibility:
Power Pack C Radial
Specifications:
Weight:
14 Oz (Fully assembled; without battery)
Wingspan: 24 Inches (610mm)
Center of Gravity: 3.25 Inches (82.5mm) from leading edge of top wing (Recommended)
Control Surface Throws: 19/30 degrees (dual rates)
Expo Suggestions: 30%
Free Plans: Click the Download Button in the upper-right corner of this page
* These plans have been updated to the latest format. The design of the model has not changed. Only the format has changed to make it easier to print and build from the plans.
Printing Instructions
DIY Templates
Videos:
Author
flitetest
Downloads
1,225
Views
1,517
First release
Last update
Rating
0.00 star(s) 0 ratings
More resources from flitetest
