Type
Build Plan (PDF, AI, etc.)
FT Spitfire
Design By: David Windestål
Plans By: Dan Sponholz
Description:
The FT Spitfire is the 10th design in the swappable series and the first of which that is a warbird. This is the perfect gateway into scale-like flying and is also a good introduction into four channel flying. This plane is great for beginners and or experienced pilots who are looking for scale lines without the unforgiving flight characteristics of most scale warbirds. This was achieved by taking the wing of the FT Cruiser and heavily modifying it with the unmistakable elliptical Spitfire wing shape, increasing the size of the under cambered wing tips and adding dihedral. The result is a very forgiving scale warbird that flies just as good as it looks.​
Specifications:
Weight: 14.9 Oz (Fully assembled; without battery)​
Wingspan: 42.5 Inches (1080mm)​
Center of Gravity: 2.7 Inches (68mm) from leading edge of wing (Recommended)​
Control Surface Throws: Ailerons & Elevator: 10 degrees | Rudder: 25 degrees​
Expo Suggestions: 30%​
Free Plans: Click the Download Button in the upper-right corner of this page
Videos:
Store Links:
Speed Build Kit: FT Spitfire
Power Pack Comparability: Power Pack C
Author
flitetest
Downloads
11,598
Views
11,598
First release
Last update
Rating
0.00 star(s) 0 ratings
More resources from flitetest
