Type
Build Plan (PDF, AI, etc.)
The FT Twin Sparrow is a new twist on an FT Classic! From chuck glider to Full FPV platform with differential thrust, this little bird will not disappoint. The Sparrow was designed to create an enjoyable and fast build experience while also teaching you all the needed skills to build any of our FliteTest designs.
FT Twin Sparrow
Designed By: Josh Bixler
Drawing By: Dan Sponholz
Date: 2018.05.10
On a 2 cell battery, the FT Twin Sparrow is a fantastic trainer that can teach all the needed to have success in flight. When you install a 3 or 4 cell, you have a fast and nimble flyer that will carve up the skies!
Our hope is that the FT Twin Sparrow will be a staple in every hangar or in the back of every car. We can't wait to see what our amazing community does with this little bird.
To access the plans, click the download button on the upper right section of the screen.
GENERAL SPECIFICATIONS:
LENGTH:
16.00 in | 406 mm
CG:
2.75 in | 69 mm
WINGSPAN:
28.50 in | 723 mm
WING AREA:
180.0 in2 | 11.6 dm2
DRY WEIGHT:
5.6 oz. | 158 g
ALL UP WEIGHT:
9.1 oz. | 258 g
WING LOADING:
7.3 oz/ft2 | 22 g/dm2
WCL:
6.5
THROWS:
12°
EXPO:
30%
CHANNELS:
3 [THR | V-TAIL]
RECOMMENDED ELECTRONICS:
MOTOR:
2X 1106 4500 kv
PROPELLER:
2X 3x3.5x3
ESC:
2X 12a min.
SERVOS:
2X 5 g
BATTERY:
450-850 mAh 2S-4S
© 2018 FliteTest, LLC. Plans provided free of charge. Copies allowed for personal use only. Not for commercial use.
Author
fliteadmin
Downloads
18,702
Views
18,702
First release
Last update
Rating
5.00 star(s) 1 ratings
More resources from fliteadmin
Latest reviews
glad to see this plan as the speed build kit seems to not be available.
