FW-42 Canard Bomber
Plane FW-42 Canard Bomber 4.0
Please log in to download
Type
Build Plan (PDF, AI, etc.)
For the 2018 Flite Test Forum Community Challenge, Team Rockyboy (Psyborg, jpo1, and myself) designed the Focke-Wulf FW-42. This canard format medium bomber was designed and wind tunnel tested prior to things fully going to pot in Europe, but never developed full scale. Focke-Wulf tried to sell contracts for the plane to Germany, Japan, and Russia but didn't close a deal and shelved the project early in the war.
This is sized for Power Pack F motors (2206) or Power Pack C as a single pusher so it's simple and affordable to build. It has a wide flight envelope from smooth and gentle to powerful enough to deal with a good bit of wind, along with all the best aspects of a canard design being nearly stall proof. I's also simple and fool-proof enough to be a good second or third plane for someone, or even someone's first DTFB build if they already have flying experience.
Why go for so simple you may ask? 'Cause I want a whole bunch of people to build them! :)
In addition to the plans in tiled format, there are printable skins too. And if you have access to a laser or needle cutter, try the gcode exported by the Easel tool here to get your 3 sheets of foam cut http://easel.inventables.com/projects/KB1zU34DuBojtJqOJVP4EQ
If you want to use the skins, you'll need a way to print out Arch D sized sheets - 24"x36" or larger. Personally I use Staples Engineering prints service https://www.staples.com/sbd/content/copyandprint/engineering-prints.html - about $5-$6 per page. Don't use their photo quality printing! Only the Color Engineering Prints!
Build instructions start at post #132 in this thread http://forum.flitetest.com/index.php?threads/ftfc18-wwii-focke-wulf-fw-42.35967/post-375684
Pusher mod built by jpot1 with a C pack motor - flew great!
Author
rockyboy
Downloads
72
Views
390
First release
Last update
Rating
5.00 star(s) 1 ratings
More resources from rockyboy
Latest reviews
Great job on the skins and plans!! Thank you very much
rockyboy
rockyboy
You're welcome! If you build one, please share some pictures !
