- Type
- 3D Print Files (STL, G-code, etc.)
The nozzle will print without support. The Thrust Tube requires support around the servo mounts.
I printed with PLA, 100% infill.
You will need to wet sand the ball-joint surfaces. I started with 400 grit, and worked my way up to 3000 grit. This makes for a smooth friction-less joint.
You will probably need to sand to fit your EDF. I used a dremel drum bit to ream it out to a perfect friction fit. I did not need to glue to the EDF.
I mounted the unit in a v-tail orientation due to limited space. It was pretty easy to program into EdgeTX.
I have included a pattern for the modified fuselage rear, as well as an additional EDF Support. This support should fit about an inch behind the other.
I have zero experience flying with thrust vectoring, but this is a solid design, and I would love to see any flight videos of it in action.
