I am pretty satisfied with the result. The first attempt of fiber glassing did not go well. I was able to save the nose before the epoxy cured.
The second attempt was better because I used a better method, and only one layer this time.
I used the fiberglass cloth that I had laying around, which said 6/10 oz, which I know does not equal 2 (2ounce was recommended), but I can always put on another layer. But I did not remove as much epoxy probably as I should have ( there is a little puddle near the rear), so I think that the epoxy may have added a whole lot of reinforcement. I do notice it is stiffer, but should I still add another layer of 6/10 oz cloth?
Before cure
after cure
Cured &trimmed
