The canopy mold is coming along nicely. I've cut, carved, sanded and filled numerous times, and it's almost ready for final prep work. It'll get covered with a layer of fiberglass & resin, followed by filler primer, spot filler, sanding, filling, priming, sanding, priming, filling, sanding, rinse & repeat. To be safe, I'll probably add a little extra "meat" to the mold first just so the canopy can be made slightly larger than needed, which should give me a little extra wiggle-room for final trimming.
Also, the ailerons are finally done so the punch-list is getting very short, and about 1/3 of it isn't really necessary before a flight:
Program TX rates and throws
Keepers on pushrod ends
Finish tail wheel installation
Glue control surface hinges
Fabricate canopy and install
Test run engine
Prep & paint cowl
Add FAA #
Make some vinyl graphics
Add a little color
Install wheel pants - maybe?
