Ryan O.
Out of Foam Board!
I got got the Evolution engine with only 3 hours of runtime, so it likely won't need many repairs. I plan to break it in a second time on the ground for good measure. Also, I've seen people run it on a glow plug, which I may do if the plane balances perfectly with only one receiver pack. If it is tail heavy, I'll get an electronic ignition, that way I have more weight in the nose. I'll also setup the control rod on the servo arm so that I get more resolution, but it won't go all the way to full travel, which I won't be needing anyways. I do think that the kit requires a servo tray, so I'll just order the one from Balsa USA. I'll be using the Miuzei standard metal gear servos, which I've had a great experience with, for the ailerons and rudder. For the Elevator I'll be using the standard size metal gear Flite Test servo for added insurance. For the covering I will use Planetex. Planetex needs Eko fill and Eko bond to work, and I still need to get those along with the wheels, copper wire, paint for the pilot, and snoopy doll. I also have to 3d print the part that attaches the prop for the dummy electric generator. The spinner will be the most challenging part because I will have to make holes in the backplate for cooling, but I will also have to make it strong enough to withstand the vibrations.
