Here is my build, I used a newer neon yellow 6mm depron like
foam that has started showing up at the local Dollaramas.
The colored side of the foam board was covered with a clear sticky vinyl available at Dollarama
The non-painted white side was covered with a thin brown packing tape from DollarTree. This adds tremendous strength and waterproofing without adding any significant weight.
The plan was edited a bit to make it ready for the laser cutter, the complete plane needed three sheets of foam (laser cutter bed is limited to 24"x18" sheets, so had to waste some foam).
This foam took significantly more power to cut compared to the Adams FB. I was concerned about the folds due to the 6mm foam thickness, however, everything fit into place with no major effort.
The plane was built using UHU Por, Gorilla glue, and 3m77. Hot glue was sparingly used to tack the wing folds and for servo mounting.
The port side of the vertical stabilizer and the underside of the fuse were covered in yellow and orange packing tape respectively. A steerable tail wheel was added. All black decals were done with black packing tape, coloured decals were face tattoos from Dollar Store
The dry weight without battery came out to ~400grams. I'm using a HK ST2004 outrunner spinning a 8x6 prop with a 2s-2000mah.
