Flew great on the A pack, but I think an F pack would be just fine, the extra weight up front would make it easier to balance. Put the battery wherever it needs to go to balance, maybe even notch out the spar to fit the battery. I had to run mine sideways to make it work.
Stick the servos as close to the front as you can or the length of your push rods. I put mine in the back which made me need a big battery.
Thanks LocalFiend
Would adding an air foil to the sliegh help it fly more level/balanced? That would change the CG all up.I suppose the added weight would make balancing even harder though. I'm still a bit new, but the lift vector should help right?
The Big Question, is can you land it on a roof?
Maybe that's the FT challange?
thank LocalFiend I am defiantly building something like this. I excitedly explained the idea to my wife on Friday and she gave me the "our neighbors already think your crazy" look. I might try and make is a little bigger as I don't have any of the mini motors. The smallest I have is a B pack.
I'm planning on getting permission from some neighbors to do some roof landings with my quad version....
Cheers!
Stick an FPV camera on it. Would be awesome.
No problem.... I did that with the spider too.
Shouldn't be too hard to put a pico FPV setup on yours too. Something small like the all in one cams used on the tiny whoop can be used to FPV just about anything. You need one more reindeer in the front, with a spinning nose. LocalFiend, the spinny nosed reindeer.
Cheers!
I can scale up the plans to B/C pack size. Should hopefully be easier to balance with lower wing loading at the larger size. I'm playing with an 8 foot version in CAD now and am doing weight calculations to see if my Tacon Bigfoot .46 motor will have enough power. Pink XPS foam from Home Depot should do the trick if things are light enough.
Scale up to B/C pack would be fantastic and I would definitely build it. And the 8 foot version would be very tempting and I just happen to have a spare .46 motor kicking around....
Thanks LocalFiend
Adding an airfoil should give you more lift at lower speed and above a certain airfoil thickness also more drag, helping you to fly slower, which in my opinion is far more interesting. Localfiend's design built extra light with fat shell/hollow airfoils might be usable indoors - great for that winter/christmas meet or the like
Localfeind: What kind of CNC rig is that? Homebuilt? I've been looking into the MPCNC design for a while myself.
localfiend would it too much to ask to have the non tiled plans? I have them printed out at a local printer and saves time . Can't wait to start this
Just sent it to the printer. can't wait to start cutting tomorrow.
After poking around in a few stores and not finding anything of the appropriate size or weight, I will probably go down the path of cutting out your templates and adapting them to my quad. May add a 3D push/pull prop on an aux channel with the ESC in 3D mode to make it possible to fly level. May try out with a "tiny" version, on the Tiny Whoop for some indoor fun too.
Cheers!
I got the plans printed out and my elf's are busy cutting them out. My hope is to have them ready for foam by the end of the evening. My wife even got me some bells for the Sleigh to show her support for the project.
Who needs a CNC when you have child labor .
My goal is to have it built and ready to fly by the weekend.
