Matthewdupreez
Ok so for the past year now i have been making my own foamboard.... yea making my own foamboard......
i used @cdfigueredo method of gluing paper onto 5mm EPS...
well that process is hard... tiresome and well when the weather is wet... the glue on the foamboard starts to rot when you want it to dry
... no offense cdfigueredo.. if it hadn't been for you i would never have gotten into this hobby.
but i had started thinking surely there is a better way to do this... more efficient higher quality......
then the other day i was watching a ft video.. can't remember which one.. and josh mentioned that their paper was stuck onto the foamboard by heat and pressure... HMMM... that got me thinking....
if i could simulate that then possibly i could make foam quickly and easily.............
first thing what does every person have lying around their house that creates heat.....toaster.... kettle.. geyser....CLOTHES IRON..
it has a flat surface and you can press down on it to simulate the pressure factor... BINGO!!!
watch the video below to find out just how to do it..
Matthew du Preez Signing off
