@dutchmonkey I really must chime in here... I have been using Inkscape 0.92 and JTech's laser plugin to process PDFs and generate gcode, for both laser and needle-cutter, for a couple of years without issue. I use "mm" units and my machines produce properly-sized output. I've just written up and posted the basic procedure I've been using and provided landscape and portrait templates for both A1 and DTFB (20" x 30") for convenience ... and they can be found
here. There were indeed issues when Inkscape's internal DPI representation changed from 90 DPI to 96 DPI with the 0.92 version but those issues have largely been resolved.
For those faithfully following Edward's procedures and Inkscape 0.91... please continue to do so. For those really wanting to use Inkscape 0.92, please check out my procedure referenced above to see that you can work safely in "mm" (or "inch") units and see properly-scaled output from your machine. I don't provide "inch" templates... but there's nothing keeping you from loading a metric one and changing the units and saving it as a new template; i.e. there's nothing to be afraid of with using Inkscape 0.92.
-- David
