Well, all the elements on the plans have the material specified - it doesn't make sense when all of them are made out of the same material; but it may be useful in cases like this. Also, I would not recommend making anything around the exhaust from such a flimsy material like paper (even if it's photo paper). It needs to be rigid and stiff enough to avoid any vibrations., otherwise it can do more harm than good.
Do you remember that I "had" to make the tail sections larger to fit the main pat of the fuselage? I choose to do that by inserting a rectangular piece of foam. It did make the fitting better, but it also increased the diameter of the nozzle (to more than 75mm). I spent the last two days modifying this part to decrease the diameter to more acceptable range:
Right now the internal diameter of the nozzle is almost exactly 70mm; and after inserting the tube (made out of 3mm Depron) it will drop further down, to approx. 64mm. That will give 17% reduction in the exhaust area (9% in diameter) compared to the EDF unit itself; which I believe is somewhere in the vicinity of the sweet spot
Unfortunately the weather forecast is worse and worse every day, with low clouds, rain/snow, temperatures balancing around freezing point and the wind gusts above 50km/h (30mph). Looks like I have at least one week more before next flight trails. And that in turn means I will drop the "one change at a time" idea and introduce as many of them as I can. And, as usual, hope for the best
P.S. And right now I realized that I probably messed up the order of actions. Since the front part of the exhaust tube will have larger diameter than the back, it will be difficult to slide it inside trough the reduced nozzle. I should probably leave the nozzle "open" and glue it together after the tube would be in place. But that's the beauty of "rapid prototyping": sometimes I tend to be too rapid...
