More power and longer battery life simply do not go together unless you can significantly improve the system efficiency.
You can't really alter the electrical efficiency of a motor but you can improve prop efficiency. The usual route is less blades, larger diameter and slower rpm which in turn means lower kV motors.
Otherwise more power means a shorter battery duration and in direct proportion or worse!
It will come down to a best compromise that suits you.
