Oh boy here's another problem. The SAFE feature is not working. I understand that 1st. You need to bind using the safe enabled method; plug in bind pin, plug in battery, take out bind pin, then bind your DX series transmitter with your desired safe enabled (and compatible) ESC. Then bind the safe feature to a switch. Thing is I've tried my landing gear multiple times as the designated safe enable/disable and I cannot seem to get it to work. The way to do this is hold both control sticks at the bottom and pointing inward, then cycle a switch with only on and off functions 5 times. What is supposed to happen is the plane cycles through the controls (or jitters for a little bit) and that lets you know you've enabled the safe feature to that switch. I cant seem to get it to work.
