Matek H743v3 not recognised in usb port
Wingspanner
I have a couple of flight controllers which connect fine to my pc. Apart from my h743. It connects in bootloader mode and I can flash it and load software but when I plug in the usb device manager does not recognise anything. I have tried the cables ect on other fcs and they’re fine. I have removed all connections from the board and checked for any shorts etc but nothing.
If you have device manager running when you plug the board in, does a device show up? If so, what does it show up as?
It sounds like windows didn't auto-assign the correct driver and you may need to manually pick the correct driver in device manager.
Odd. I'd reach out to Matek and see if they have any ideas. Or the vendor you bought it from to see if they can exchange it.
I have an original H743-wing and never had any issues with it.
