not a great picture who shows the nuances in colors... its more or less shadowed with silver the hole bottom of the plane, with some visual "points" to easier see direction in flying.
it should been some 4blade props... but havent found the ones i need. 8x 4-6" 4 blade prop also as CW/CCW is hard...Scale props, scale flaps, retracts, and the "No way....that's foam board!?'" comments that I am sure U will get @ the field. Too cool .
That looks incredible!
i will. The flaps is ok and working... the rear geardoors i have some problems with, started change mechanism to get it better functionalWould you take some pictures of the Flap mechanism you ended with, and the gear doors. you indicated it was a lot of trial and error, but it struck me as good to see what you settled on. or some details on the canopy?
Thanks.
I cannot wait to see this in the air.
Plus being a twin it should just cruise with ease.I think there's going to be no shortage of lift..... blended wing/ blended nacelles. Such a fine bit of workmanship!
Peter
magnificentView attachment 202013 View attachment 202014 View attachment 202015 View attachment 202016
the pictures, and light at moment doesnt show good enough paint. Main color is Antrasit grey, with silver fogging at bottom, and minor light "brownish" fogging at top. It shows better at angle , where gives a feeling of changing color hue..... Im satisfyed with the paint and build!
Minor "deflection" happend in some of the panels who was shaped both ways (dome - styled) it changed a bit back , and shows up a little close to the main spars.. its not much though... perhaps woudnt happend if even some formers more.
Weight though, would sacrifice by used more materials. its fully 1950grams with a 4000 mAh battery.....
First taxi testing. one rear wheel hanged a little (an easy fix though) and gave turning direction... easier see a bigger front wheel would be nicer. Its in mail though
Thanks.
Thank you VERY much. so the Rod with the stopper is held to the servo with a u-guide on each servo arm. then rod then extend back into the fuse, when the gear is retracted but when extended it stopper hits the arm and it is a pull-pull system connected to the collar for steering.... The Video and pictures are great!here you see flaps function. Its a servo down into fuselage that actuate a pushrod to the flap/airbrake.
Also retracts , and retract door function / setup. A spring from a writing pen adjusted to get the correct tension. Fastned in the door and to a screw on the retract leg. I tried get the function with mechanical rods, but either it slided on the wheel, loosing good enough movement, or retractdoor get stuck too the wheel shutting it from ended fully, if used mechanical rod father rearward to the retract leg.
The spring system was best function on. And as long the ends are closed, so cant "jump off" its nice.
Front retract steering, is by "push-pull" system with pushrods.
Well video got a small "coffebrake" in middle, needed change battery with enough voltage
here is also pictures of the steering system. When retract is closed, the pushrods disengage at the servohorns, "pushes" more back, and stoppers is not in contact with the servohorn. When retract is lowered, pushrods goes forward and engange the servohorns because the stoppers.
This plane is great. do you feel it is read for a maiden flight?
