Resource icon
Mighty Mini Sea Duck 1.2
Please log in to download
Horseman3381
@Horseman3381 Is the wing spar an A or B fold in this build? And to confirm, when you say "This should be mounted with the U spar in the upright orientation." this means with the wing down on the table, it is glued with the U upright?
Sorry for the delayed response, I kept getting an error message when I tried to log into the forums the past few days.
@AIRFORGE is correct. It is a B fold, and with the wing down on the table the U should be upright.
TommyG_FPV
I finished my Duckling today (that's what I'm calling it now lol), except the cowlings and pontoons. It was a little tricky for me to get all the electronics to wire and sit correctly, I had to switch up the steps a little bit.
For example, I wired everything into the wing, then I made a bit of a "hinge" on the bottom of the fuselage cabin in order to put it on after the servos were installed in the wing. This worked well.
I also sat the battery tray down as low and far forward as I could. Can't wait to put the finishing touches on and get her airborne!
