• Welcome to the new Flite Test Forum home! Please note that the migration is still undergoing and certain content, user privileges or features may be missing or limited until the transition is complete. Thank you!
Mini Arrow 3D Printed Center Pod
#2
very nice. i have built multiple arrows for myself and others and just love this wing. i have seen a few other 3D printed center pods but had been very hesitant. my current printer can do PLA and ABS and neither seemed like the best option. i have a new printer on the way and it will be able to do nylon, so i might just have to try this.
what ESC and battery are you running? looks a little small for a 20A. i have never had any luck running a 2204 w a 12A ESC in this wing using a 3S. way to much. even with a 20A, a 3S, and 6045R prop, i was pulling 22A @ full throttle.
laters,
me ;)
#3
Thanks. PLA warps too easily, so not an ideal material. ABS should be fine, it's just trickier to print. You may want to look into PETG, I've had great luck with PETG on things like this. Pretty easy to print with, but MUCH better temp resistance than PLA. I use it in my car for a phoen holder, and no issues all summer in the heat.
I'm running the stock Power Pack F (2204 and 12A ESC) spinning a 6x3 or 6x4.5 prop. As long as I keep the ESC in the airflow, I've never had problems in the past...but if I put it inside, forget about it....starts burping/cut-off after only 30 seconds or so.
BTW, the .STL files to print your own can be found here https://www.thingiverse.com/thing:1972543
:applause:
my newest is running an A-pack 1806 w/6045 and a 12A ESC. i put the ESC on the outside today and it flew much better but it really needs the 2205 for my personal speed needs... :rolleyes: it was very windy today so i plan to fly it again tomorrow before i change anything just to make sure.
i will check into the PETG.
thanks.
me ;)
#6
laters,
me ;)
20 amp is hardly enough?I thought a 20 amp would be an over kill.
#7
As long as it's exposed to airflow allowing it to stay cool, I've never had an issue with the smaller ESC's on this plane. I do think they should change the build video a bit to make outside placement the normal build process. Other than that, super easy build and a great little everyday flyer that's easy to leave in the car for quick flights.
If I build another I may try to extend the motor back from the wing a bit and see if that helps quiet it down. It might be small, but boy is it loud wide open! :p
