BATTLEAXE
These are some great pics, a lot of info can be gained from these. Your wing sweep doesn't look to drastic which explains the 1/2" change in CG. There are some things we can play with and a couple suggestions you have the option to consider. I think the one servo to swing both wings thing will work really well, it will be easy to program it to a "position 1/position 2" switch on your Tx. But once you scale up, like it was mentioned before you may have issues with wing flex at the pivot joint, especially under positive loading. Even in flight to switch from one mode to another may stress the pivot joint and the servo. If you look up KFM wing designs this might help out in the flex.Ok so here is the Mini Moth 2.0. It has been scaled up 150% and now has a bottom mounted vertical stabilizer. @BATTLEAXE the last picture shows how far back the CG moves when the wings sweep. More info coming soon.
The rudder you installed isn't going to be very effective, although the fuselage will give you yaw stability to a degree it won't be enough to stabilize the plane, considering you have such a short distance from the wing to the tail. One way you can overcome this is to make your tail feathers a V-tail design. You already have them angled up some but in that position they just work like an elevator stuck in the nose up position. A V-tail will still give you the look your trying to achieve but be way more effective as control surfaces. And because of the short distance between your wing and tail they may work like elevons still. In a V-tail design you can eliminate the rudder all together, effectively cleaning up the design.
Something else you can play with as well is using small counter balance weights that pivot forward on an arm opposite of the wing, wing swings back, arm moves forward, maintaining your CG no matter where the wing sits. I don't know if this has been done before, just an idea off the top of my head. You may want to do some research on YouTube or google to see if there is anything on it. Again just an idea to try in the experimental design phase before you scale up. Actually a good question to you is, When you chuck glide with the wings back, does it pitch down compared to when the wing are forward?
