Greetings all,
Virgin quad builder that's run into a problem binding my Lemon RX to my Spektrum DX7s. Got the quad built and powered up without letting any magic white smoke out. (Score!) However, I can't seem to get the Lemon RX into bind mode. After scouring the internet and following the instructions I located, I'm beginning to wonder if it's a wiring problem. My particular LemonRX came with three black wires; no color coding whatsoever. So I have no clue what's power, signal or ground. I decided to pickup a small 1.5mm female molex figuring that would alleviate my issue. I'm not so sure I didn't wire it in backwards though.
I'm using cleanflight to configure things and did the following:
Connected the Naze32 via USB to the board and it powered up no problem
In the ports tab, choose UART2 : enabled RX = Serial RX
In the receiver tab, I selected "Enable Serial-based receiver" and Serial receiver and selected the SPEKTRM2048 for DSMX
Typed the following into the CLI "set spektrum_sat_bind = 9" then typed "save" and watched it reboot.
After disconnecting power from the naze and plugging in a battery, I get bumpkis for lights on the Lemon RX. I mean nada............but no smoke either. If I wired it in backwards, wouldn't I smoke it? Or is the positive on the receiver also in the middle? I'm just not sure the molex connector is oriented correctly.
Any thought's or insights would be greatly appreciated! Apologies for the long post. Here are a couple pics for reference:
