Scratch
OK… Im in need of some FPV equipment, but I honestly don’t know much about FPV stuff yet and am looking for some help. This is what I have:
A homebuilt H-Quad with DT750’s, Plush 30’s, 11X4.7 props, multiple 2200mAh 3S LIPO packs, The FCB will be soon be a KK2.1, but is now an i86.
I also have a GoPro Hero 3 (black edition), a Sony camcorder, many different security system cameras, and lots of 12VDC 4.0Ah and 7Ah batteries (I’m in the security system install business and have access to many of them) and 12VDC vehicle batteries if needed.
I want this FPV equipment to do a couple things…
1. Obviously, I want to be able to use it to fly my multirotor in FPV mode from maybe 300 yards distance or so, using a small shaded screen (like a 7” or so) no goggles at this point.
2. I’m also into .308 precision rifle shooting, and am wanting to be able to mount a camera on a tripod, setup about 6 feet away from my target at an angle, and be able to view it at up to 500 yards away, straight line, on a 7” (or larger… screen.
I’ve set up my camcorder for shooting, and am happy with the detail of the target image that I can see from it. I have a private range near my house so I’m not concerned with having to setup 12V batteries to either the TX side, or the RX side of the system, but am also ok with using car batteries if needed.
What I’d like to do, but I’m not sure if it’s even possible… is to use my GoPro, with the GoPro composite cable, and connect it to the video TX on the multirotor, and use a 7” or so LCD type screen hooked to the video RX, inside a “shade box” or whatever you call them, to fly with.
Then when I want to use it for shooting, I’ll remove the video TX and antenna from the quad, hook up my camcorder to it on a tripod, and set that up with a 12V battery near my target… then setup the video RX at my shooting bench with another 12V battery to view with on an LCD screen. (7” or larger)
I’m not sure if I’m forgetting a major portion of this or not, or what I need to purchase to accomplish both tasks. Here’s what I “think” I need, but have no idea on which parts to order:
FPV FLYING SETUP:
TX END
Video TX/RX system
GoPro 3 black (already have)
GoPro composite cable (do I need to mod this, or will the TX have RCA inputs?)
Antennas for TX on the quad
Small battery pack for the TX on the quad (2200 mAh 3S maybe...?)
RX END
Larger battery for the video RX (already have…
Antenna for the video RX
Some type of viewing screen
Homebuilt shade box
Battery for the viewing screen (already have…
FPV SHOOTING SETUP:
TX END
Same video TX/RX system
Camcorder on tripod
RCA cables to TX (already have…
Antenna for TX at the target (same as above I hope…
Larger battery for the TX at the target (already have…
RX END
Antenna for the video RX (same as above I hope)
So what I'm looking for, is examples of:
Video TX/RX systems that will work for both systems
Antennas for TX/RX
Any odd cabling I havent thought of maybe...
Battery packs for TX on the quad (or can I use the 2200 3S?)
Small screen for flying (hoping to use the 7" for shooting, maybe upgrade later)
And any ideas or flaws with my thought process?
FPV FLYING SETUP:
TX END
Video TX/RX system
RX END
Homebuilt shade box
FPV SHOOTING SETUP:
TX END
Camcorder on tripod
RX END
Antennas for TX/RX
