quorneng
There is a huge difference between the effects of wind and turbulence on a model plane, particularly a very light one.
Wind if fairly obvious. You can feel it and it is constant although it does tend to get stronger the higher up you go.
Turbulence is caused by things on the ground and the completely disrupts the airflow. This means that as far as a model plane is concerned the air it is travelling through can in the space of a couple plane lengths change its direction both horizontally and vertically. This is likely to have a very dramatic effect. To make matters even worse a gentle wind, the sort that you might feel safe for a slow flyer creates relatively even more severe direction changes.
Low level ground turbulence can persist for many times the height of an object. Down wind of a full height tree can persist for the length of a football pitch.
So if your plane has a flying speed of say 15 mph and you fly in a gentle 5 mph wind it would be quite manageable but any turbulence effects and it is likely to be thrown about almost to the limit of its control.
Not quite the same thing but this picture does show the lasting effect of wind turbines on smooth misty conditions.
Of course in normal clear air conditions you will none of it but it is still there.
