Hello everyone,
I finally finished building my first FPV quad. It is a 3S MHQ2 (3D Printed). I built it as a starter quad so I learn the ins and outs, and then can move on to a better quad. Everything is working smoothly, except for one thing: the FPV system. I am using a Runcam Eagle, TBS Unify Pro (Not HV), and TBS Triumph. I am running the Unify on the 25mW power level. For some reason, a few seconds after I start flying, the video signal starts cutting out and I end up crashing because I can't see. I thought that maybe I was getting too far away and needed a higher power level, so I switched it to the 200mW setting. However, as soon as I throttle up to a certain point, the signal immediately cuts out, but returns when I throttle back down. I can repeat this over and over, but each time it will cut out after I throttle to a certain point. Could the Unify not be getting enough power? Could this be a range issue (what should the range be on the 25mW setting?) Could something else on the quad be interfering with the video signal from the Unify?
Thanks so much, I appreciate any help I can get.
