Looking at the specs on the C pack 2215/10 motor the input voltage is a 2-3s (7.4 – 11.2V). But then in the overview it is stated the C pack ESC is sufficient for 4S and to use a 9X4.5 prop on the motor for 4S. Also in build videos (Mig3) Josh states he likes a XXX 4S battery.
The current listed for the motor is 18 amps or 200 watts.
If I using a 4S battery Is the important number 18 amps or the 200 watts.
I would need to keep the current to about 13 amps if 200 watts is the target number.
In either case I know watts would be heat the motor would have to deal with.
Watt / amp meter coming in the box with new batteries, I will have the tools just lacking knowledge. I have a lot to learn about motors.
