recommendations for hot wire foam cutter
Belial2801
Hello, I am about to start this new project and I have some doubts about the tension I should apply and the size of the cable. I would like to know your recommendations or if what I plan to use for this project is correct. Here is a short list of what I will use:
Nicrom wire (75cm long)
Ac adapter 12v 1A
Here are my main doubts, for the length of the cable, would 12v and 1A be enough or should I add more amperage?
Site Moderator
It depends on the thickness of the nicrome wire & how hot you want to run your wire. I think you will need more amps & possibly more volts.
Here is a good calculator https://jacobs-online.biz/calculators.htm
Look around on this site, lots of information for hot wire cutting.
I use several transformers for various cutting applications. I use a simple light dimmer switch on all of them. Pass the mains voltage through the dimmer to the transformer, then dial in the heat you want. I shoot for a dull red color if my nicrome. A bright red makes too large of a kerf.
Belial2801
I forgot to mention that, I plan to use 32 awg but, I don't know if 28 awg nichrome works too,
Site Moderator
19v 3A do you think is better?....
The calculator said with 32 guage you will need 30v at just over 1 amp. 28 guage wire 21v at 2 amps. I use 26 guage wire, so I would need 17v at 2.6 amps.
I use a 24v transformer & my light dimmer to dial it back, but then my wire is a bit longer than yours If I try to go to fast, I can easily break a wire. Im sure 32 guage wire will be quite easily broken.
danskis
#32 sounds a little thin to me, too. Start with something thicker. I agree with Merv - start with #26 or thicker.
Belial2801
#22 should be good? It is the thinnest one I found but I still have a little doubt about the voltage and amperage so, I will try different voltages.
