FoamyDM - Luscombe Silvaire
Plane FoamyDM - Luscombe Silvaire 1.0
Please log in to download
Type
Build Plan (PDF, AI, etc.)
INSPIRATION
I was asked to try my hand at designing the Luscombe Silvaire from a forum friend, @kilroy07 . He explained how he loved and hated this plane. He loved it for the memories he has with his father in it (see below), but he hated the elbow grease required to shine this beaut' up. "Motorized polishing is to aggressive and eat holes through the thin skin" elbow grease was the ONLY way...
I took it on for him and it fit into the FTFC20 - Classic to Modern challenge and I added it as an entry. I also really love the smooth/ rounded fuselage, and the wing plan form. It was going to be a new technique again and design a Master Series Plane. and thereby worth all the marbles. so I got to work. A started with sketchup, flattened and the fit curves to the sections. Turned out great!
FREE PLANS Click the Download Button in the upper-right corner of this page
SPECIFICATIONS
DESCRIPTION IMPERIAL METRIC
Length 26 in 508 mm
Center of Gravity 2 in from wing base 0 mm from wing base
Wing Span 53 in 635 mm
Wing Area 326 in2 21.9 dm2
Dry Weight 12.4 oz 350 g
All Up Weight 17.7 oz 500 g
Wing Loading 7.47 oz/ft2 23 g/dm2
Park Flyer/Trainer
RECOMMENDED SETTINGS
THROW HI LOW EXPO
Ailerons 􀀔􀀕􀂃 􀀛􀂃 35%
Elevator 􀀐􀂃 􀀐􀂃 35%
Rudder 􀀐􀂃􀀃􀀃 􀀐􀂃􀀃 35%
RECOMMENDED ELECTRONICS:
Motor 2822 1200kv or 2215/09 1000kv
ESC 30A BRUSHLESS
Prop 8"x4.7 or 10x4.7
Servos 4-9g
Battery 2200 mAh 3S-11.1v
Build Information
Build Log.
When you build it, Please be sure to add picture either here as a comment / discussion, or over in the forum Build thread
Author
FoamyDM
Downloads
64
Views
463
First release
Last update
Rating
0.00 star(s) 0 ratings
More resources from FoamyDM
Latest updates
  1. Flight vid
    I added the flight video. In good wind this was a strong flyer
