As you can see in these pictures, finish sanding has yet to happen.
Also, what looks like gaps between the sheets is actually some kind of hard filler, and based on how hard it is to cut I wouldn't be surprised if it were some kind of epoxy.
Before doing the final sanding and covering I had to take a step back and make an area to hide the power, ignition, and light switches. I could simply mount the switches inside one of the doors, but that's less convenient than I'd like once the wings are attached. The option I'm going with is making a "luggage door" which is simply a small door meant to load/unload luggage from the plane. I don't think the Cessna 150/152 actually had this, but other versions did and my name isn't Joshua so the scale detail isn't that big of a deal!
First step was determining size and location.
A little happy-time with the knife left a big hole in the side of the plane. But is that the other side of the fuselage you can see? Nope, just an odd design quirk found on many Hostetler plans!
The fuselage is basically a box inside a box. The inner box is a simple structure with flat sides and the outer box gives you the nice curves. My L-19 from Hostetler is designed like this as well - it's very durable. So basically I'm going to use a quirk of the design to keep my switches hidden. The door to access the switches will either be held on by magnets or a hinged side, I'm not sure which yet.
The hole is getting sides, a top & a bottom which will give me plenty of room inside for multiple switches.
