Thanks Timmy P for the awesome plans. This is my second post on the forum. I have been building FT planes (and thanks to FliteTest) for about a year or so and I really enjoy seeing what others are doing. I get a lot of inspiration from the community so I thought that I would also post some pictures of my build.
Once again, thanks for the hard work on these plans. It really is appreciated.
So, if I can figure out this whole forum posting thing...here it goes.
I started by using Ross foam board. I like to use this stuff because the paper does not peel off as easy. I don't have to use hot glue on the hinges then. Also, it is brighter white and doesn't see to warp as much. Not quite as durable though. This is just my preference. I have used DTFB in the past and it works pretty well too.
I print the plans and then tape together. Then I use some old marble cheese slicer slabs to hold the plans to the foam board. The piano wire on the cheese slicers keep breaking and the handles fall apart so I have them just laying around. We're pretty rough on the cheese slicers here in Wisconsin.
So anyway, I weight the plans down and use a push pin to mark all of the lines and junction points. Then I use a straight edge to connect the dots and hand draw all of the curves. This reminds me of the good old days in high school drafting class. When you actually had to use a pencil to draw...
Next step, cut the parts out. The only trick I use here is making the slots for the tabs. I can never seem to hold the blade straight so the slot comes out all weird on the other side when I try to cut straight through. So now I cut only 50% on one side. Then I punch a pin through so that there is a little hole on the other side of the part at the four corners. Then I cut the other side 50%. Bam! A nice, square slot.
So, here is my progress so far. I will keep posting. Ya know, this is really cool that there is a community that is:
1. very positive and genuinely helpful to others
2. willing to share a wealth of knowledge and ideas
Thanks again.
