Okay so I just can't stop tinkering with everything.
I also soldered the voltage alarm on. I did some de-soldering to disconnect the part you would connect to the servo on a airplane. Just to get it out of the way of the RX. (Gremlin is tiny!!!)
Then I prepared the wires to be soldered on the the batter pads, in tandem with the battery connector. If I would have know I was going to do this during the build I would have done a Y solder with the wires. But whatever, it works.
(I wouldn't attempt this unless your confident at soldering, everything is VERY tiny and you have not much room with all the other components in there)
This shows how much room you have to play with if anyone stumbles across this and wants to copy it.
It's all quite a tight fit.
But it works!
