Pieliker96
Introducing the Cormorant II
A Twin-Engine Transport Plane with Fowler Flaps and Drooperons
What is this thing?A Twin-Engine Transport Plane with Fowler Flaps and Drooperons
The Cormorant II started as an aircraft in Kerbal Space Program, a rocket/plane/rocket-plane simulator game that got me into aerospace. The goal of the craft was to be an aerobatic cargo plane with decent STOL capability. I accomplished this by the Kerbal mantra of "More Boosters" (engine spam), as well as adding massive flaps and leading-edge roll control surfaces. In 2019, I stole its name for a RC plane of a similar goal, of which I was never really happy with the performance - The thrust to weight ratio was lower than I wanted, and roll authority and stability were both lacking. I was planning on scrapping that airframe for a new design, and decided to try and replicate the craft from KSP, which this is the result of. It's got a high wing for roll stability, big externally blown offset-hinge fowler flaps for slow flight, more powerful motors for more thrust, and drooperons to increase roll authority as inspired by the original KSP aircraft and this video of Ben Harber & his Zupair Zulu. Changing the name felt wrong, as this new airframe was more true to the original; I settled on "Cormorant II".
Electronics & Configuration
It runs on Twin Power Pack F (2x RS2205 on 6x3/4.5 or 5x4.5x3 props) and a 2250 3s. All-up-mass is 900g, which gives it a thrust-to-weight of 1.5 with the 6x4.5 props. It has a 51.6" span and a wing cube loading of 6.9. It uses 4 or 6 9g servos, depending on if the builder chooses to forego the flaps. The flaps can be configured as split or fowler, with the latter using craft sticks for the offset hinge. The optional drooperons enhance roll rate for the more aerobatically-oriented pilots.
Building Details
This plane is intended for someone who has prior experience with Flitetest plans and planes - it is not a good first or second build. The wing is a traditional FT style wing, and the fuselage is closer to the FT Master style of construction: Is uses formers and skin to form a semimonocoque shell, as opposed to the simple box style with A and B folds and the like.
Plans
Cormorant II Plans (v1.2)
Build Video
Flight Video
