I'm a newbie builder. Can you more experienced folks recommend a brand and/or type of cutter for cutting push rods/control rods? That wire is hard! The needle nose plier side cutters that I've been using will work when I exert maximum force but I don't know how much longer the blades on the cutter portion will put up with that. I can see indentations in the edge every place I've made a cut. Your ideas and suggestions are hereby solicited and will be most welcome!
